People Skills : 6588 Registration date : 2009-03-14 Age : 35 Location : Miami, FL / Atlanta, GA
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:20 pm
godughifu wrote:
Sean Rubin wrote:
Jeff L wrote:
godughifu wrote:
Sean Rubin wrote:
and you would also need to find out how and where the shrapnel from the opponent's robot will go. If inside the robot...need an open space. If outside...how?
You'd basically have to make the robot kind of like a carwash type thing
Have the stationary blades just 'open' on the top and/or bottom (not open as in move, open as in they're just sort of sitting out there with no armored casing). The blades would be only capable of taking a certain sized chunk out at a time, which would likely ride along on the blade until it just fell out. You would want the robot capable of driving over the little chunks that would fall pretty much under your robot though, unless the blade spun upwards, which would mean the debris could be dealt with much easier.
But then it would be a drum. Wouldn't shred easily. It needs to spin down.
No it needs to spin sideways.
@ Sean: spinning upwards is fine, so long as the stationary blades are positioned correctly.
@ Dughi: It actually doesn't matter at all what direction it spins, you just want to pick the direction it's most likely to catch onto something and pull it in. Downward is actually the easiest and most reliable method, particularly if the crusher is built into the surface of a wedge.
That Guy samurai jesus
People Skills : 6014 Registration date : 2009-03-16 Age : 31 Location : Pinecrest, Florida
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:25 pm
but car wash type thing is cooler.
People Skills : 5954 Registration date : 2009-03-16 Age : 31 Location : Miami
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:26 pm
MAKE YOUR NEXT POST A GOOD ONE!!
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:27 pm
It also wastes valuable weight.
Oh, and for clarification, I'm thinking this weapon could have a single blade (or set of blades on one axle), and the other set is completely stationary and non-driven.
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:29 pm
BUT THATS NOT AS FUN JEFF, WE NEED TO MAKE THIS FUN!!!!!!!!!!!!!
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:30 pm
Shredding robots into tiny pieces is fun enough already. If you want more fun, give it a silly paint job or ridiculous running lights.
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:32 pm
MAKE IT PINK WITH FLUFFY THINGS AROUND THE TOP AND A BIG RIBBON!!
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:33 pm
AND CALL IT BUBBA!!
Subject: Re: The Idea Dump Mon Apr 13, 2009 11:34 pm
They both need to be spinning Jeff, what if something gets caught in the non-moving one and we can't get it out cuz that one needs to go in reverse to get it out?
Subject: Re: The Idea Dump Tue Apr 14, 2009 12:05 am
Nope, jamming would not be a problem with a single spinning blade and a fixed blade, as long as the rotation direction for the spinning blade could be reversed. Trust me, you do NOT want do have to deal with two sets of spinning blades.
People Skills : 6380 Registration date : 2009-03-14 Age : 32 Location : Sarasota, FL
Subject: Re: The Idea Dump Tue Apr 14, 2009 10:14 am
i was thinking about this and i thought up a kind of funny way to suck robots into the grinder. have a super-strong and thick cord or cable or something like that, and have it so that one end is fixed, and the other is retractable but very powerfully so, so it makes half a loop extended out on short arms. Have them rotate so that they start off pointing up, then very quickly snap down so the cable goes around the bot, then retract the end of the cable to squeeze the other bot into the grinder...
something like that?
Subject: Re: The Idea Dump Tue Apr 14, 2009 12:08 pm
The cable idea could work out pretty well, but for this setup it's not entirely necessary. Mainly it depends on where you decide to put the shredder; if the shredder is on top of a wedge, just driving into another robot should be enough to keep it in position.
Subject: Re: The Idea Dump Wed Apr 29, 2009 5:26 pm
"Top" Spinners
Jeff L wrote:
We actually had a kind of insane idea a while ago that sort of goes like this: what if you had robots with a single high-speed motor, a few servos that can wiggle the batteries around, a huge spinning weapon, and no drive system? Once they spun up they'd act like tops that you could move around by shifting the center of mass of the robot on two axes by shifting the batteries. You could also handle any issues with skittering around by having little spring-loaded kickstands that get pulled up by centripetal force once it's above a certain RPM. (I'm putting this in the Idea Dump)
People Skills : 7825 Registration date : 2009-03-16
Subject: Re: The Idea Dump Wed Apr 29, 2009 6:13 pm
if you look on Near Chaos robotics website one of the team members has already designed something similar that i guess he is making some progress on IMO its almost like melty brain
Subject: Re: The Idea Dump Wed Apr 29, 2009 6:21 pm
yeah, the only problem I can think of is making sure it's the shell that spins and not the internals. It shouldn't be impossible to make sure the right parts spin though, helicopters manage to make it work just fine. It'll be a bit of a different kind of engineering challenge though.
Subject: Re: The Idea Dump Wed Apr 29, 2009 6:36 pm
but helicopters do it with that funky sideways rotor to stop the body from spinning... the internals would need some sort of high-friction ground interface or something...
Subject: Re: The Idea Dump Wed Apr 29, 2009 6:39 pm
You might be able to use an internal wheel with its own motor contacting the disk to hold the internals steady - similar principle to what helicopters use, different implementation.
Subject: Re: The Idea Dump Wed Apr 29, 2009 6:59 pm
very true...
MattTavares big contributor
People Skills : 5674 Registration date : 2009-04-11 Age : 36 Location : Dallas, TX
Subject: Re: The Idea Dump Wed Apr 29, 2009 10:37 pm
Whats wrong with internals spinning? didn't you see blender mini this year?
Subject: Re: The Idea Dump Wed Apr 29, 2009 10:46 pm
If the internals are spinning you're wasting energy that could be going 100% into driving the weapon. Also, making a good control system would be a royal pain for spinning internals. With 'heli-style' internals you can actually do some fairly interesting things in terms of maneuvering - for example, you can rotate to face a new direction insanely fast. It wouldn't move quite as fast forward or backward as a robot with an omni-drive would (since it would rely on its weight shifting around), but that's fine really. Along with that, you actually could make the entire robot 100% invertible, and far more resistant to damage (no wheels). Really, it's sort of in-between meltys and typical spinners.
Subject: Re: The Idea Dump Wed Apr 29, 2009 11:17 pm
I don't care what anyone says. spinning internals can be cool too. mabye not as effective but who dosn't like gravity defying robots???
People Skills : 6064 Registration date : 2009-04-21 Age : 30 Location : Sudbury, MA
Subject: Re: The Idea Dump Wed Apr 29, 2009 11:20 pm
i just noticed something matt, your shell changed color at the comp because it is red in another video.
Subject: Re: The Idea Dump Wed Apr 29, 2009 11:29 pm
Well you see. I used a special charged molecule that allows me to change the color of my shell by running different colors through it.
ok mabye not.
actually the red one was my backup shell. . I had enough divets here and there on the first shell from the first match that I said why not and changed it out. I liked the red one's looks better anyway!
Subject: Re: The Idea Dump Thu Apr 30, 2009 12:00 am
the bad ones totally bad ass And as for spinning internals, if you had them spinning right with the shell (ie melty brain) your not really waisting energy but adding weight to your weapon
Subject: Re: The Idea Dump Thu Apr 30, 2009 12:12 am
aha, but this one should be considerably more difficult to immobilize, so long as it's made out of the right materials. There's also just the plain coolness factor of having a giant top for a robot with no apparent exterior mechanisms to control its movement.
