| The Idea Dump | |
+11MikeNCR jeeves_m_d MattTavares Julien Kuzniarek Will Bales That Guy Sean Rubin Dan Curhan Alan Dreher Cody Jeff L 15 posters |
People Skills : 6588 Registration date : 2009-03-14 Age : 35 Location : Miami, FL / Atlanta, GA
| Subject: Re: The Idea Dump Mon Mar 23, 2009 3:18 pm | |
| Electric Crusher
This isn't the most common weapon type in combat robot circles, but it has an excellent track record. Usually driven by hydraulics or pneumatics, smaller versions are possible using electric motors. One variant I came up with a while ago used some of the lessons learned from X-Contamination to build a crusher arm. The intended drive system was one to four high-rpm motors, geared down to sixty RPM as a maximum, driving the linkage system of the crusher arm. The arm itself would be made of either titanium or hardened steel. As an optional add-on, either a carbide tip or a Ferrium C69 tip could be designed into the crusher's point.
This is an extremely feasible design, just not commonly built. In fact, I think a hobbyweight crusher was entered in Motorama a few years ago. | |
People Skills : 5954 Registration date : 2009-03-16 Age : 31 Location : Miami
| Subject: Re: The Idea Dump Mon Mar 23, 2009 9:48 pm | |
| - Emissary42 wrote:
- Electric Crusher
This is an extremely feasible design, just not commonly built. In fact, I think a hobbyweight crusher was entered in Motorama a few years ago. i think the only successful electric crusher has been x-contamination. let me know if im wrong... so i can see why it isnt commonly made. drums have been at the top for a few years now... | |
That Guy samurai jesus
People Skills : 6014 Registration date : 2009-03-16 Age : 31 Location : Pinecrest, Florida
| Subject: Re: The Idea Dump Mon Mar 23, 2009 9:51 pm | |
| - CuddleBunny wrote:
i think the only successful electric crusher has been x-contamination. let me know if im wrong... so i can see why it isnt commonly made. drums have been at the top for a few years now... I'm pretty sure X-contamination isn't a crusher, it's a flipper. A crusher is the opposite of a flipper, it "crushes" by trying to puncture the other robot by pushing down where as X-Contamination flipped by pulling up. right? | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 9:58 pm | |
| Didn't x-contamination do both? | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:01 pm | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:08 pm | |
| hmmm...w/e. from the videos ive seen it seems that way. | |
People Skills : 6380 Registration date : 2009-03-14 Age : 32 Location : Sarasota, FL
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:15 pm | |
| do you guys remember the puerto rican bot that picked up its opponent and put it ON TOP of a lowered arena hammer? I want to do something like that, where it's a pincer bot that holds the opponent, then a super-powerful crusher/armor-piercing spike type thing comes down and pulverizes. Theoretically, the pincers could squeeze too... have a quick grab mode then a slow constrictive death-squeeze mode. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:19 pm | |
| I think it would be awesome if somebody made a robot that basically had a garbage disposal type weapon. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:21 pm | |
| like opposing grinding toothed discs pulling in toward each other and like lobster/shrimp legs out front to feed the other bot in... I VILL EAT YOUR SOUL! MWAHAHAA!!! (like that?) | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:23 pm | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:24 pm | |
| And with the ridiculously overpowering paper shredder blades we found, we could do it too. those things are frickin ridiculous. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:25 pm | |
| i doubt thats allowed tho...its pretty much the same thing as hooking | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:26 pm | |
| No, X-Contamination did not have the power to be a crusher. At one point I did make (and install) two steel "fangs" on the arm so it could possibly cause some damage or grab onto robots with large holes in their armor (such as what people usually do for weight reduction, but openings for wheels would work just as well). Even though it didn't cause actual damage to any robots beyond minor scratching, the way the point system is set up in Battlebots means X-Contamination gets a point every single time it hits the other robot with its arm (I believe it falls under 'aggression'). This is why in old videos you can see X-Contamination kept firing the arm as often as possible when its opponent was pinned under it. | |
| No its not. If you're actually destroying those parts, then you can back away and you're not entangled at all, thats the goal of garbage disposal bot. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:30 pm | |
| - godughifu wrote:
- No its not. If you're actually destroying those parts, then you can back away and you're not entangled at all, thats the goal of garbage disposal bot.
So...how do you make it so when you back away...the parts jsut fall out... its gonna be stuck in it. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:31 pm | |
| they're not there, you're basically crushing and shredding the other robot and the pieces are just flying everywhere. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:32 pm | |
| Oh...i get it now. I thought you would shred it and then "eat" it. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:33 pm | |
| it would have to spin kind of slowly and have a really powerful drive and feeder mechanism, then just reverse itself. Or, to totally spite the other teams, have a bucket that all crunched off parts fall into, and have a dump mechanism that just dumps it all back into the arena. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:34 pm | |
- Oh...i get it now. I thought you would shred it and then "eat" it.
- Dan Curhan wrote:
- it would have to spin kind of slowly and have a really powerful drive and feeder mechanism, then just reverse itself. Or, to totally spite the other teams, have a bucket that all crunched off parts fall into, and have a dump mechanism that just dumps it all back into the arena.
EXACTLY. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:35 pm | |
thats fucking hilarious. but just so mean. WE SHLD DO THAT!! | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:36 pm | |
| Why do you think I brought up the paper shredder blades? | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:37 pm | |
| we ought to just team up everyone and just build stuff. for fun and competition if we're lucky. oh, to have endless amounts of time and money..... | |
| - Dan Curhan wrote:
- we ought to just team up everyone and just build stuff. for fun and competition if we're lucky. oh, to have endless amounts of time and money.....
thats actually a really good idea. but wed have a tough time getting together and actually working on it. | |
| Subject: Re: The Idea Dump Mon Mar 23, 2009 10:39 pm | |
| How epic would an ALL FLORIDA TEAM be? We take like the best from the schools in Florida and we team up to build EPIC BOT and use it to rape the competition at BotsIQ. | |
| Subject: Re: The Idea Dump | |
| The Idea Dump | |
